Unable to locate the link instance corresponding to a port from VLAN library
Check port instance. If it is valid, check the group Id. Else, contact the concerned personnel with the exact set of sequences that led to the logging of this message.
Warning
Logical port instance, Lif does not exist %lifId%
| Name | Type |
| lifId | uInt32 |
